dial 9 didn't work for softphone
I have a situation like this:
two router patterns on the CCM.
9.@ with calling transformation 416437xxxx, so that specific DID can be displayed on the called phone.
8.@. with calling transformation *67. If people dial 8 to access outside, *67 will block displaying the ANI .
Everything works fine for IP phone.
What weird is softphone however can't dial 9, otheriwse wil get a fast busy tone. But dial 8 no problem.
If I change the transformation 4167437xxxx on 9.@ to *67, then works. I have no any idea about that.
Any idea, thanks
1 REPLY
Silver
Re: dial 9 didn't work for softphone
I suspect that the call manager configuration for the IP Phone and Softphone is not the same. Did you by any chance miss adding the partition containing the "9.@" route pattern to the Calling Search Space of the Softphone ? Can you just double check the configuration of the Softphone.
88
