09-14-2006 01:19 PM - edited 03-13-2019 02:58 PM
Hello, I would like to decrease the delay after dialing a 4 digit extention number. All of our internal extension numbers start with 6 or 7, is there a way to shorten this delay. Currently it waits about 6 seconds after you hit the dial softkey. Thanks
Ash
09-14-2006 01:48 PM
Ash,
Assuming you are using CallManager, you want to adjust the CCM Service Parameter, T302 Timer, which is the interdigit timeout. Usually this doesn't affect internal dialing unless you have variable length patterns starting with 6 or 7.
Please rate any helpful posts
Fred
09-15-2006 08:11 AM
Thanks Fred, I've turned it from 7000ms to 3000ms, makes a world of difference.
