You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Dial-out not working in PLAR confgured between VG200 & ICS7750
I'm trying configure PLAR between FXO of VG200 and FXS of ICS7750. dialing from PSTN to PHONE works fine but PHONE cannot dial-out to PSTN.
PSTN--FXO--VG200--ETHERNET--MRP--FXS--PHONE
VG200(12.2.13b)
voice-port 1/0/0
connection plar 4800
dial-peer voice 100 voip
destination-pattern 4...
session target ipv4:172.17.0.11
dtmf-relay h245-alphanumeric
dial-peer voice 101 pots
preference 1
destination-pattern .
port 1/0/0
MRP(12.2.13.ZH2)
voice-port 0/0
destination-pattern 4800
port 0/0
dial-peer voice 110 voip
destination-pattern T
session target ipv4:172.17.0.12
If I delete the dial-peer 101 on MRP, successfully dial-out to PSTN even PLAR not working.
I tested same configuration between VG200s and it works fine both direction.
any idea why it doesn't work in ICS7750 ?
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: Dial-out not working in PLAR confgured between VG200 & ICS77
I fixed by adding a "clid strip" under the dial-peer of MRP.
clid strip
port 0/0
97
