Dial peer help
I have a Call Manager hooked up to a router which is configured as follows:
voice-port 1/0/0
connection plar 29990
voice-port 1/0/1
dial-peer cor custom
dial-peer voice 1 pots
incoming called-number .
destination-pattern 91..........
direct-inward-dial
port 1/0/0
forward-digits 11
dial-peer voice 100 voip
incoming called-number 4570
destination-pattern 2....
session target ipv4:172.16.200.5
dtmf-relay h245-alphanumeric
codec g711ulaw
My IP phone service provider recently told us that we can use 7-digit dialing also, I'd like to do international dialing but not sure how to implement these on the existing dial plan.
Any help will be greatly appreciated.
Mitch
1 ACCEPTED SOLUTION
Silver
Re: Dial peer help
Your requirements is similar to the typical north american numbering plan - 7-digit, long distance, international.
A simple setup would be
1. In Callmanager, create a route pattern 9.@ and point it to this gateway. Use the discard instructions "Pre Dot"
2. In the gateway, create a dial-peer as follows
destination-pattern .T
direct-inward-dial
port 1/0/0
3. You would need an additional route pattern and dial-peer for 911 calls
Anup
1 REPLY
Silver
Re: Dial peer help
direct-inward-dial
port 1/0/0
Anup
254
