Dial-peer matching question and sho dial-peer voice sum
Hi - I have two questions that may be related to each other. I have a router with 6 inbound POTS lines and I want to match a single incoming POTS peer to route all calls to the onboard IOS/TCL/AA script service.
I'd like to have a single POTS peer match for all incoming calls to hit the IOS/TCL/AA:
dial-peer voice 5000 pots
service siteaa
incoming called-number 5000
However, there is no match until I put a voice port specified on the dial-peer.
service siteaa
port 2/0/8
The analog port is defined as such:
voice-port 2/0/8
timeouts interdigit 3
connection plar opx 5000
So do I need to define 6 POTS peers - each with one analog port defined - in order to send all calls to the IOS/TCL/AA service?
Also, when I show the POTS peer, this is what I get:
C2821-TestRouter-HQ(config-dial-peer)#do sh dial-peer voice sum
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
PORT
5000 pots up up 0 down
2/0/8
What is the OUT/STAT column in SHO DIAL-PEER VOICE SUMMARY? It shows "down" in this case.
Thanks.
Re: Dial-peer matching question and sho dial-peer voice sum
A dial-peers operational status is down unless you specify the port command. I havent tested this personally with multiple dial-peers but i would think, all you would need would be to specify one dial-peer with one of the ports. Worth giving it a try!!
Thanks, Shanky. Not to contradict, but check out this URL:
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_tech_note09186a008010e6d1.shtml
This says that a dial-peer is operationally up with only the incoming called-number specified without a port. However, if it is destination-pattern, then yes you need a port (POTS) or target (VoIP). If you look closely at the SHO DIAL-PEER VOICE SUMMARY, it does show operationally up - but there is a new column (12.4 mainline) - at the very end - that is OUT/STAT. Thid doesn't appear to be the operational status.
Any comments are appreciated.
Kyle,
you are right. i was wrong abt the op. status.
The 12.4 voice command reference guide doesnt ttell any abt what that field means.
Since this is an fxo, i think this is what you should do.
-----Edited-----------
voice service voip
voice-port 1/0
connection plar 5000
dial-peer voice 1 pots
incoming called-number . -- this is to match any inbound call, regardless of port.
int lo 0
ip add 1.1.1.1 255.255.255.255
dial-peer voice 2 voip
service site1aa
codec g711ulaw
no vad
dial-peer voice 3 voip
destination-pattern 5000
session target ipv4:1.1.1.1
codec g711ulaw
no vad
Sankar
PS: please remember to rate posts!
561
