Dial-Peer matching question
I'm not understanding why a call to 9011573006161957 is matcing the POTS dial-peer that it is:
dial-peer voice 12 pots
description RRB Extentions
preference 1
destination-pattern [2-9]
direct-inward-dial
port 3/0:23
forward-digits all
Can someone explain? I would think the pattern should be [2-9]T or something to be a full match, but it seems to be matching on a single digit.
RRHB-VXR02#show dialplan number 9011573006161957
Macro Exp.: 9011573006161957
VoiceEncapPeer12
peer type = voice, information type = voice,
description = `RRB Extentions',
tag = 12, destination-pattern = `[2-9]',
answer-address = `', preference=1,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 12, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 3/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = pots, prefix = `',
forward-digits all
session-target = `', voice-port = `3/0:23',
direct-inward-dial = enabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
Time elapsed since last clearing of voice call statistics never
Connect Time = 359480959, Charged Units = 0,
Successful Calls = 17574, Failed Calls = 6906, Incomplete Calls = 275
Accepted Calls = 295, Refused Calls = 52,
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 365210802.
Matched: 9011573006161957 Digits: 1
Target:
Re: Dial-Peer matching question
I guess as soon as you dial the first digit itself, its a specific match ([2-9]), so its ignoring the rest of the digits. Does the call complete ?
Are you saying that any single digit match that eliminates any other destination-patterns will automatically match on DialPeers?
Does the CM operate the same way?
thx.
Silver
You need to have a T at the end of the pattern so the interdigit timeout takes effect. Else it would match on the first digit like Sankar said.
destination-pattern [2-9]T
But if you are positive that you want all calls to go out a certain trunk, should you just leave it like that to make call routing faster? The inbound matching peer is an H323 peer, so all digits are known already.
145
