When using MGCP gateway with SRST. What is the correct order for the dial-peer statements? Do mgcpapp ones come before the voip ones? Can you use the command "no ccm-manager config" and configure all of the dial-peers manually?
you will need to configure the dial-peers manually, and you do not need to turn off ccm-manager config
In my same scenario, I only needed 1 dial-peer for mgcpapps
The rest of the order does not matter as it will choose the peer with the best match.
