Dial-Peer Statement
Ma Bell is at it again... my once 7 digit local toll calls are now 10 digits +1.
example: 94481212 would go out 90. Now caller must dial 918144481212 which hits dial peer 92. I would like for the callers to not have to dial the additional 1814 to complete the call.
How can I force a call out a specific dial-peer without hitting each Dial-Peer until it gets a match ?
dial-peer voice 90 pots
destination-pattern 9[2-9]..
progress_ind alert enable 8
port 2/0:23 (local calls)
dial-peer voice 92 pots
destination-pattern 918.........
port 4/1:23
prefix 18
  • Other Collaboration Voice and Video Subjects
Re: Dial-Peer Statement
set up a translation pattern in CM
You can use a prefix if you alter your destination pattern a bit.
If you define your destination as 9[2-9]......$ which forces a specific 7 digit long match, you can then prefix the 1+ area code.
Your dial peer would then look like this:
destination-pattern 9[2-9]......$
prefix 1814
port 2/0:23
78
