Community Member
dial plan issue
I'm implementing a distributed-model ip phone project. It involves about 10 sites/cities, with each site having a Call Manager & some 7910s & a gateway(3662) to PSTN, except in one site the gateway connects to a PBX. Gatekeeper is implemented too.
The customer requires the following dial plan: within each site, dial xxxx(4-digit); between sites, dial area code PLUS xxxx(4-digits). Is this possible? How?
If the project only invovles calls between ip phones, then it seems I can use Gatekeeper setting in Call Managers to do this(allow anonymous device, significant digits). But with the pbx & PSTN, I'm not sure if this still works, as I think IOS gateways don't act the same as the anonymous device(intercluster trunk protocol) allowing significant digits.
Thanks for your help in advance.
1 REPLY
Re: dial plan issue
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
107
