Dial problems 4.2.3
The problem that I am having is rather confusing to me since I had not run into this
before.    I have a pattern set up as 5XXXX which works great on all patterns with the exception of
511XX.  I can dial the 511XX before pulling dial tone and the call connects but if I pull dial tone first
then I get to 511 and get call can not be completed as dialed.   Also not sure why put two phones
set the same way both 7970's one will force diall the 511XX and completes the call and the next will
dial the numbers one at a time and gets the call can not be completed.
Everyone's tags (2)
1 REPLY
Re: Dial problems 4.2.3
Most likely you have dial plan overlapping and the phones have different CSSs to cause that.
Take a look at the dial plan to see what you're reaching or use DNA to troubleshoot this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
405
