Dial Rules Configuration Problem 3.3.3
I recently upgraded a customers CallManager from 3.2.2c to 3.3.3. After I completed the upgrade I was checking the pull down menus to make sure that everything was working properly until I came to Route Plan > Application Dial Rules. The screen that came up had an error message as follows:
Error: Cannot access dial rules
Couldn't get dial rules: com.cisco.ma.dirdata.MADirException: UserId doesn't existDirectory Operation
failed, Other reason
Please check if the Directory service is paused or stopped
I checked all of my required services and they running normally.
Any suggestion to fix this problem would be greatly appreciated. This seems to be the only problem that I had during the upgrade.
Jim
1 REPLY
Re: Dial Rules Configuration Problem 3.3.3
It looks like you are running in to CSCeb67162. To confirm the bug please go to start -> programs -> DC Directory Administrator -> users
You should see CCMAdministrator and CCMSysUser. If you do not see it you should check out the following URL and will need to go to 3.3(3)SR1 or SR2 which has the fix.
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCeb67162
Hope that helps,
ketan
87
