Dialed and displayed B number must be the same
I have 4 callmanagers connected to 1 router with 4 BRI ports.
In order to have the phones that are registered to a particular callmanager use a certain BRI port I added a prefix in the Route Pattern (for example 11 for the first Callmanager) which matches the destination-pattern on the dial-peer (dial-peer voice 1 110.T).
This works fine, but.....
when a phone user dials 0030....etc. the displayed number on the phone is 11030...). I want the displayed number to be the same as the number the user has dialed, NOT the number the router uses to make a match with a dial-peer.
Silver
Re: Dialed and displayed B number must be the same
Coud you try changing the display number pattern in CCM and check
Where in CCM is this setting located?
232
