ā04-01-2006 12:40 AM - edited ā03-15-2019 04:14 AM
I have two 2651XM Routers, each of them has a h323 gateway configured. On Router 1# there is a dialpeer to an E1 port configured. On Router 2# there is a GSM Gateway configured. If the dialpeer to the GSM GW is busy (2 channels are in use) the h323 GW on Router 1# (E1-PRI) should be selected.
How can I configure this. The two GWĀ“s are in a route-group.
thx for help
ā04-06-2006 10:15 PM
the parameter change did not help.
I'm running CM4.1(3)SR3a with 2 H.323 gateways
ā04-06-2006 10:52 PM
Hmm.. I've used this parameter on older versions of CM successfully in this config.
How are your gateways set up in CallManager? Are they both in the same route-group, or two RGs in one route list?
Aaron
ā04-06-2006 10:56 PM
I use a route group with topdown:
1=GSM-GW, 2=PSTN-GW
Also tried a route list with both groups in it, but still no luck
ā04-06-2006 11:57 PM
in response of your pictures i attached two pictures of my solution.... route-grp and route-list....
the dialpeer-config:
dial-peer voice 664 pots
destination-pattern *00T
port 1/1/0
prefix 0
(i use a prefix because on the same router i have the voice-backup briĀ“s)
