02-20-2004 01:56 AM - edited 03-13-2019 03:55 AM
I installed the FXO card on CME router. Is that possible to enable DID on FXO card ? so if someone call particular number then it will be forwarded to the cisco ip phone. I have done this on E1 card, but I am not sure about FXO.
many thanks for any feedback
thanks
santo
02-20-2004 06:42 AM
No, but Cisco does makes a card for analog DID.
It is VIC-2DID.
02-20-2004 05:23 PM
What kind of line should I connect to VIC-2DID ? Is it similiar like FXO lines ? I heard that it's only for incoming call, not for outgoing call. is that true ? My requirements are actually I need DID and outgoing call on the same lines. Do you ever know about VIC2-2DID ? what is the difference with VIC-2DID ?
thanks alot
-santo-
02-21-2004 07:02 AM
You would get analog DID lines from the carrier. And yes, it is true , you cannot use the DID lines for outbound calling.
If you to get DID and inbound/outbound calling is use ISDN PRI.
03-01-2004 08:29 AM
How many phone numbers are associated with each analog line? If there is only one number per line you can simulate DID using the plar command in the dial peer. I have done this for a small CME implementation and it worked well.
