DID not working with CM 3.2 and VG200/E1
I'm in real big trouble. I can't get DID working.
We have installed a CM 3.2 cluster and have 2 VG200 with E1 interface for ISDN access.
Today i found out, that DID is not working correctly. If i make a call from a IP-Phone, the number is send as a block and DID is working perfectly.
But that's normal for Germany.
In Germany we use normaly Overlap Sending and Receiving. Any DID digit send one by one.
This is the debug output from "debug isdn q931":
5d01h: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x001C
5d01h: Bearer Capability i = 0x9090A3
5d01h: Channel ID i = 0xA98381
5d01h: Progress Ind i = 0x8283 - Origination address is non-ISDN
5d01h: Calling Party Number i = 0x00A3, Plan:Unknown, Type:Unknown
5d01h: Called Party Number i = 0xC1, '28032', Plan:ISDN, Type:Subscriber(local)
5d01h: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x801C
5d01h: Cause i = 0x8081 - Unallocated/unassigned number
The caller dialed 2803-2345 and not 2803-2.
How can i get DID working? I tried already adding following statements to the dial peer
dial-peer voice 9991015 pots
incoming called-number 2803....
direct-inward-dial
But it did not change! Very bad for me!! ;)
What needs to be done, to get DID working?
Cu
the current config:
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname mdhl-vg200-1
logging rate-limit console 10 except errors
voice-card 1
ip subnet-zero
no ip dhcp-client network-discovery
mgcp
mgcp call-agent 172.17.12.9 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode cisco
mgcp sdp simple
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
no mgcp explicit hookstate
call rsvp-sync
isdn switch-type primary-net5
ccm-manager redundant-host 172.17.12.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.17.12.9
ccm-manager config
controller E1 1/0
pri-group timeslots 1-31 service mgcp
interface FastEthernet0/0
ip address 172.17.12.7 255.255.254.0
duplex auto
speed auto
interface Serial1/0:15
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.12.1
no ip http server
voice-port 1/0:15
application mgcpapp
port 1/0:15
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Re: DID not working with CM 3.2 and VG200/E1
Do you have the OverlapReceivingForPriFlag service parameter for CCM set to True? This is a callmanager service parameter.
Thank you,
-Mckee
Yes. I set this parameter to True, reseted the gateways, but nothing changed.
I can't find any documentation, explaining what is needed to get DID working.
Would it be possible, that i need to change something more?
Cu
OK!!!!!!!!!!!!!!!!!!!!!!!!!!!
I got it working!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
There was a translation pattern missing. You need to add translation pattern for the complete number.
1234.XXXX
and discard pre dot.
After that everything is working.
Cu
Bronze
no ip address
"isdn overlap-receiving t302 2000"
no cdp enable
Try it with the Command above.
Mehmet
I does not help. It did not change something.
Thanks for you help.
Cu
I found this information that you maybe able to use in your configuration problem. see if there is policy setting that are set that you are over looking.
Modular QoS Command-Line Interface Classification and Marking Example
The recommended classification and marking method is the Modular QoS Command-Line Interface (Mod QoS CLI, or MQC) feature, a template-based configuration method that separates the classification from the policy, allowing multiple QoS features to be configured together for multiple classes. You use a class map to classify traffic based on various match criteria and a policy map to determine what should happen to each class. Then you apply the policy to incoming or outgoing traffic on an interface using the service-policy interface configuration command. The following configuration example shows how to use Modular QoS to classify and mark packets:
Configuration Example 4: Classification and Marking Using MQC
access-list 100 permit udp any any range 16384 32767
access-list 100 permit tcp any any eq 1720
class-map voip
match access-group 100
policy-map mqc
class voip
set ip precedence 5
<<#various other QoS commands>>
class class-default
set ip precedence 0
interface Ethernet0/0
service-policy input mqc
In this example, any traffic that matches access list 100 will be classified as class voip and set with IP Precedence 5—meaning that the three most significant bits of the IP TOS byte are set to 101. Access list 100 here matches the common UDP ports used by VoIP and H.323 signaling traffic to TCP port 1720. All other traffic is set with IP Precedence 0. The policy is called mqc and is applied to incoming traffic on Ethernet interface 0/0.
The article below may help.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/qossol/qosvoip.htm#xtocid63559
Fred Sweezer Sr.
Nice to know, but not helpful with my problem! ;)
Cu
Bronze
Which version of the IOS is it ?
I think it is 12.2.8T (I have heard it cant overlap receiving,but i am not sure).
mehmet
I'm using 12.2.2(XN). I tseted also other version, but i had the most success with 12.2.2(XN). This version seems to have the best support for callmanager.
Or does someone have something against 12.2.2(XN).
Cu
Bronze
I had the same Problems with 12.2.2(XN) on isdn BRI.
I have now installed the 12.2.8T.
Mehmet
Ok, but if i see that you use ISDN BRI, than you are not using MGCP. Right?
As i know, the Callmanager does not Support MGCP with ISDN BRI.
I think my Problem is a Callmanager Problem. Any L3 signaling is done on the callmanager(ISDN PRI Backhaul). So i think it must be a Callmanager Problem.
Let's see .... :)
Cu
125
