Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
DID T1's in 3640 running MGCP...Possible??
I've got a 3640 that will be housing the dual HDV T1 module with two T1 PRI's coming in providing DID.
My question is whether or not MGCP should be used in this situation or not? The only configs on the web that I could find for DID basically had the Dial peers set up for DID at the 3640 level config, without any MGCP reference.
I need to know if Callmanager should be used to configure patterns to route the dnis numbers being passed down, through MGCP on the gateway, or better yet can it do this function.
1 REPLY
Re: DID T1's in 3640 running MGCP...Possible??
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
100
