02-05-2003 09:09 AM - edited 03-12-2019 10:34 PM
I am trying to translate one of our unused DIDs to the route point of personal assistant. The call comes in a h323 gateway via a PRI. I can translate it to any phone and even the media ports of PA but not the route point or AA route point.
PA is version 1.3.4
Call manager is 3.2(2c)
the gateway is 12.2.8T1
Has anyone seen this before? If so how do I get around it?
02-05-2003 10:45 AM
might be a codec mismatch..
02-05-2003 11:32 AM
It is trying to setup g711ulaw
02-05-2003 12:04 PM
Do you have "codec G711ulaw" configured on your voip dial-peer? VoIP dial peers default to G.729.
02-05-2003 12:34 PM
yes
02-05-2003 10:52 AM
Instead of translating it, try configuring a CTI Port with your DID as the DN and do a call forward all to your PA RP.
02-05-2003 11:35 AM
Same results as the translation pattern, I had also tried that via a phone forworded to the PA route point
