Difference between HDV-1E1-30 and DE30+
What are the pros of each one.
If i want a E1 connection to a PBX can i use each?? The HDV-1E1 can manage up to 60 voice channels to the PBX or for transcoding and i can scale the DSP´s.
On the other hand, i read in the description of the DE30+, i have the feature of display the caller id with name+number for in- and outbound calls. But the connection to the network it only 10BaseT.
Can i use both together in the same location??
Which development is the newer one??
Are my advisements right??
I have a MCS7835 and a 3640.
Thanks for your opinions and hints!
Martin
1 REPLY
Re: Difference between HDV-1E1-30 and DE30+
Well, since you already have the 3640 router, it may be advisable to go with the HDV E1 interfaces. One reason is that if you use the NM-HDV-2E1-60 you can handle 2 E1 circuits in one slot.
Feature-wise, the DE-30+ is similar. They will both handle ISDN signaling -- including caller ID number and name if present -- approximately the same.
92
