Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Differences between web-based and comma-delimited reports
Does anyone have any ideas why when I run a port usage report for the past week and select web-based I can see all the days, but when I select comma-delimited it only shows the past 2 days?
Re: Differences between web-based and comma-delimited reports
Taking a quick look through DDTS there are several outstanding report bugs related to CSV, but most of them are formatting and header issues, I don't see one specific to this issue.
If you're in a jam and you want the port usage info in CSV format the MDB file generated by the reports engine is left around on the system (the same MDB file is used for WEB or CSV formats). You can pull the info you're likely looking for from there is you need to. You can also check out the ports busy report off AnswerMonkey - source code for it is also posted:
http://www.answermonkey.net/App_busy_port_report.htm
Thanks, Jeff. Funny thing... I ran it a second time and everything showed up. I gotta upgrade to 3.1
243
