Digit manipulation problem for outgoing call
Dear sir
I am facing problem when i tried to dial just 2xxx for remote branch(fours digit it does not dial).
But when i dial with 2xxxxxx (seven digits its work fine and call land on my destination remote phone). with this rule
voice translation-rule 100
rule 1 /^2....../ /215205524/
but it does not work when i use
rule 1 /^2.../ /215205524/
it does not dial , i have attached my complete gateway configuration ,kindly check the dial-peer matching, i think i m missing something in dial-peer.
Could you plz correct my configuration , As i am using CCM with h.323.
you assistance will be higly appreciated
thanks
my Scenario is to dial 2xxx (four digits and call should land on my remote destination , as i do with 2xxxxxx (seven digits)
1 ACCEPTED SOLUTION
Re: Digit manipulation problem for outgoing call
you just need a translation pattern in CCM
place on that says 62XXX in pt-internal
then do translate called party to
2052XXX and choose a CSS that can find the phones at the remote branch and walla!
HTH, please rate useful posts!
Chad
Silver
you should rather use sth like this:
rule 1 /^2\(...\)/ /215205\1/
But maybe you can't call to short numbers because you have dial plan collision. 2xxx and 2xxxxxxx have the same beginning and after you dial 2xxx CCM is waiting for inter digit timeout. Short dialing should have different prefix.
regards,
PK
I tested both of these rules and they both work, have you checked your Route Pattern on the CM?
Also have you tried to debug the gateway to make sure the 4 digit call is even making it to the GW?
in your conf
voice translation-profile 1
translate called 100
dial-peer voice 400 pots
translation-profile outgoing 1
destination-pattern 6T
this will never cause a translation since you have you translation matching only number that START with 2, and the only dial-peer you have configured that translation on is a 6T.
What are you trying to do?
Chad
What i wanted to do is basically i want to take PSTN dial done by pressing 6 . than want to dial 2xxx digits so my call will land on remote branch IP phone.
I am using call manager and i have a route pattern 6.@ in CCM.
your assistance will be higly appreciated.
Chad
125
