Direct-inward Dial (DID) for IP Phones on 1760-V
Hi All,
Does anyone know whether 1760-V(with ITS Feature) support DID for IP Phones if I have ISDN PRI on it ??
many thanks
santo
Silver
Re: Direct-inward Dial (DID) for IP Phones on 1760-V
If you have ISDN pri, you cna do a direct inward dial and ring any corresponding IP phones. In other words, yes this will work.
Taimoor
thanks for your reply. I have another question about ITS. I want to have voice mails by using Cisco Unity. I have tried to configure. and I conclude that one voice mail for each user it will take one physical phone port. That means that if I use ITS router which supports up to 24 phones and each user wants to have voice mail, total users will be 12 phones and another 12 phones will be taken for voice mail. Is that correct ? or is there any separated license for voice mail so it can have more phones on routers ?
Eventhough I didn't confgiure on the router they appear on the router themselves
Here are the example, the unity registered to the ITS router
ephone-1 Device:CiscoUM-VI21 TCP socket:[-1] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:192.168.0.77 17789 Unity Voice Port keepalive 26 max_line 1
ephone-2 Device:CiscoUM-VI22 TCP socket:[-1] activeLine:0 REGISTERED
IP:192.168.0.77 17790 Unity Voice Port keepalive 26 max_line 1
ephone-3 Device:CiscoUM-VI23 TCP socket:[-1] activeLine:0 REGISTERED
IP:192.168.0.77 17791 Unity Voice Port keepalive 26 max_line 1
ephone-4 Device:CiscoUM-VI24 TCP socket:[-1] activeLine:0 REGISTERED
IP:192.168.0.77 17792 Unity Voice Port keepalive 26 max_line 1
thanks
santo
283
