Direction needed for AS5350 call looping issue
Specifically, I can get into a voice ?hairpinning? or loop issue between the as5350 and pbx when certain digits are passed to the as5350?passed to the pbx and back to the as5350 (until all the DS0 channels are used up!). So, I?d either like to figure out how to just dump the calls or stop the hairpinning (POTS to POTS basically)
Can someone point to some useful links. Thanks.
1 REPLY
Re: Direction needed for AS5350 call looping issue
You can use huntstop keyword on dial-peers to stop hunting past that dial peer which may help depending on the dial-plan.
But it sounds like you have a bigger dial-plan issue to address if calls come from 5350 to PBX then back to 5350.
What digits are being passed that come back and cause hairpinning situation?
105
