Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Directory Handler problem using PDL's
I have a second directory handler set up in Unity 4.0(1) for a particular site. The customer wants to restrict dial-by-name searches to just users at that site. When I go to the Directory Handlers -> Search Options screen for this directory handler and press the "Select" button next to the "Public Distribution List" option, the pop-up window comes up but the "Domain" drop-down list is empty and the "Next" button does not do anything.
How can I fix this problem and set up the directory handler to only search the PDL for that site?
1 REPLY
Re: Directory Handler problem using PDL's
If the domain drop down list is empty this normally means you have a DC/GC configuration issue where Unity is pointing at an invalid GC/DC and can't populate that info - do you get the same kind of skinny (empty) drop down list when you go to import a subscriber? If so this is almost certainly the issue at hand.
See this thread for details on what to check in the registry for this:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.ee91397/2#selected_message
87
