Community Member
DIRT (Disaster Recovery Tool)
I have configured a Failover Unity. According to Cisco web you are suppose to use DIRT to back up a failover unity. The forced back using dirt works without any problems. The problem I have is when I attempt to do a scheduled backup. Within Disaster Recovery Backup I go to options, Scheduled Regular backups I receive the following failure. 'Run-time error '429': ActiveX component can't create object'. Has anyone else had this problem with DIRT?
Re: DIRT (Disaster Recovery Tool)
that hasn't been reported - what version of DiRT are you running?
Community Member
Version 1.0 Build 76. Unity is 3.1(5).
Yeah, build 76 is a number of versions old now... Buil 89 is currently out there for the backup and 1.0.217 for the restore. Snag the latest version from here:
http://www.ciscounitytools.com/App_DisasterRecoveryTools.htm
See if that throws the same error or not - if it does, ping me back and we'll see if I can see something in the log.
Community Member
That worked. Thanks
217
