DiRT for 2.46
Looking at AnswerMonkey and UnityTools, it seems that there isn't a DiRT for 2.46.. Is this the case? If so, then how am I going to replace the existing hardware, or move the Unity db from one platform to the next?
I've tried dbExport.. but, it fails and looking at the logs, during the task of Exporting the mailusers. Since this fails, I'd like to create a clean NT4 and E5.5 box.. thinking that maybe the DS in E5.5 is corrupt.
Lee
1 REPLY
Re: DiRT for 2.46
No, there's no DiRT for 2.x... since the data was all stored in the Exchange 5.5 directory instead of in a nicely portable SQL database it makes it almost impossible to make a "migration" tool like DiRT on 2.x...
if dbExport is failing it likely speaks to the fact that something is wrong with your database that needs some fixing - you probably wouldn't want to try and move it as is anyway.
The only supported mechanism for moving hardware platforms in 2.x is using a full backup package like Backup Exec and restoring it onto another server.
80
