07-02-2003 07:28 AM - edited 03-13-2019 12:34 AM
When I perform the backup it works without a problem but when I try to restore after clearing the config with configmgr then running the configuration setup again then a reboot when I try to restore I get the error "error:53 file not found in procedure baccountmailstorerights of form frm frmMain.
Did I forget a permission somewhere?
07-02-2003 07:32 AM
which version of DiRT restore are you using? That error would indicate it's looking for a file it expects to be there (likely SARA.EXE which checks the send as/recieve as rights on the mailstores we'll need them for when restoring messages if you have that option selected).
There was a bug in a couple older versions of DiRT restore that may be biting you here - be sure to get the latest version off www.CiscoUnityTools.com if you haven't already.
07-02-2003 10:11 AM
The version of DIRT is 1.0.0.218 Unfortunately I do not see a file only the info from earlier message.
07-02-2003 10:13 AM
1.0.225 is the latest... you can fetch it from here:
http://www.ciscounitytools.com/App_DisasterRecoveryTools.htm
07-02-2003 11:54 AM
Thank You that fixed the restore it worked nicely.
