DiRT SQL errors
I am getting the following error when I run Dirt:<br><br>(error) in cmbBackup routing:[Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open backup device 'Z:\dirtbackup\UnityDBBackUp.sql'. Device error or device off-line. See the SQL Server error log for more details.<br>[Microsoft][ODBC SQL Server Driver][SQL Server]BACKUP DATABASE is terminating abnormally. number=-2147218303<br>(error) in cmbBackup routing:[Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open backup device 'Z:\dirtbackup\ReportDBBackUp.sql'. Device error or device off-line. See the SQL Server error log for more details.<br>[Microsoft][ODBC SQL Server Driver][SQL Server]BACKUP DATABASE is terminating abnormally. number=-2147218303<br><br>Unity 3.1 Build 3.1(2)<br>Unity Disaster Recovery Backup 1.0.72<br><br>What can I do to correct this?<br><br><br>Stan Smith<br>Communications Engineer <br>Boise State University
Anonymous
N/A
Re: DiRT SQL errors
Very likely you don't have rights to write to that Z drive mapping (I've seen this in a few cases). Try selecting a local drive as a test to make sure it can write through... the "Can't open device" error when you have a mapped drive is almost always going to be a permissions issue for a share, however.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
Re: DiRT SQL errors
Thanks for the help. I was successful running DiRT locally.
Stan Smith
116
