Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DIRT Utility
When attempting to use the DIRT utility I get an error attempting to backup the SQL portion. The error indicates that the mapped drive cannot be opened, yet all other files are successfully copied. The SQL log indicates that there is an access error to the mapped drive. Is this because SQL is unaware of the mapped drive???
1 REPLY
Re: DIRT Utility
No, mapped drives are used regularly in our testing and in the field use of the tool. You have another issue at hand... can you do a backup to a local drive as a test?
218
