03-12-2003 03:43 AM - edited 03-12-2019 11:01 PM
Is it possible to disable the network settings on an IP-Phone so that a user cannot see the phone settings if he press settings > network configuration at his phone. I Think I read that this is possible in CCM 3.3. But I find nothing how to do it.
Achim
03-12-2003 04:45 AM
I don't know that it is possible to disable the ability to view them. With CCM 3.3 you can disable the ability for someone to change them through the phone.
03-12-2003 04:57 AM
How can I do this?
03-13-2003 04:51 AM
You can do this by going into the config page for the phone in question via CCMAdmin and the very bottom parameter in CCM 3.3 is "Settings Access"......set that to "disabled" to lock the settings out.
03-13-2003 08:43 PM
Yes Setting this to disabled will disable the Settings button. When a user hits the button nothing will show on their phone.
03-14-2003 09:33 AM
Then how would the user change their ring type and contrast? Does it still allow them to do this?
We are running 3.2.2c waiting for a CRS upgrade that will be compatable with 3.3.
