Disable T1 with CCM 4.1.3 and MGCP
Is there a way to disable or place a t1 into a maintence state from the web interface? I need a way to keep traffic off of a t1 while testing things without having to change alot of programing. I know I can do a shutdown from the router but is there anything avalible from the web interface?
1 REPLY
Silver
Re: Disable T1 with CCM 4.1.3 and MGCP
Yes, on a T1 PRI. Not on a T1 CAS.
For the T1 PRI you can use the service parameter "Change B-Channel Maintenance Status" to place it in maintenance.
Make sure you check the "Enable Status Poll" at the gateway.
Anup
88
