Disconect Supervision not working in a 3660 with FXO and cptone Mx
I have a 3660 with FXO ports connected to a PSTN lines in mexico, I can finish calls perfectly, but when I make a call and the called side (PSTN) terminate the call first, the FXO port do not close the connection and still active until I disconnect the line or reset the call in the GW.
I have IOS 12.2(6)a and I configured the ports with the "cptone mx" and "supervisory disconnect dualtone mid-call"
but it does not recognize the disconnect tone.
I see that I can configure the tones manually but I need the tones (frequency) and cadence for Mexico tones, someone know them ? please post them, because I don´t know where to find them.
or someone know any other country code of cptone that can work fine with the Mexican analog lines?
TIA and Greetings !!
Alcon
1 ACCEPTED SOLUTION
Re: Disconect Supervision not working in a 3660 with FXO and cpt
This may help you http://www.cisco.com/univercd/cc/td/doc/product/tel_pswt/vco_prod/mex_sup/. I think you have to purchase the tones.
This was not the full solution, but helpme a lot with the frequencies tones and cadence.
Thanks a loot.
The service is working now, Thanks !
196
