Disconnect Cause Code
I am using an AS5300 as a terminating Voice Gateway connected to PSTN by R2 signaling (digital , non compelled).
one of our carriers who is sending traffic to us via a GK , is getting a lot of Normal , unspecified disconnect cause code such as :
F69 : 13931692hs.34640 +-1 +872 pid:1000 Answer
dur 00:00:00 tx:0/0 rx:0/0 1F (normal, unspecified.).
Note That for the same carriers some calls are terminated succesfully.
for other carriers ther is no problem ,
so it s not a config problem , and i did not find any fix on CCO
any suggestions? , what can be the source of problem ?
Jacob.
Re: Disconnect Cause Code
Hi jacob,
Are they using the same equipments as other carriers ?? what equipments other's are using ??. Just a thought, check with call slow or fast start with that carrier.
Thanks for your reply ,
Yes , the same equipments are being used( for that carrier and Others) which are Cisco Brand AS5300 , and the signaling deployed form that carrier( in trouble) is ETSI PRI.
Could you elaborate on your reply ? what do u mean by "check with call slow or fast start with that carrier. "
Jacob.
122
