Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Disconnect problem with CISCO 2610 Router
Hello!
I have a big problem with my CISCO 2610 router.
It's configured to be able to carry out a VoIP network.
I can call from any land line (fixed phone) from Romania (I'm from Romania) at a local number, I receive a message like "Welcome to CISCO...", I enter an account number and then I call any number from US (for example).
Everything goes fine except one thing: after I close my connection, I mean I hang-up, the voice port doesn't disconnect for about 4 or 5 minutes. So even if there's no phone call, the line is busy for 5 minutes.
I've tried to set up the "Wait Release Time Out" parameter and "Call Disconnect Time Out", but there's still that problem.
What on earth can I do?
Can you help me, please?
Here is some configuration, if you need more just tell me what:
CISCO-GW#show voice port 1/0/4
Foreign Exchange Office 1/0/4 Slot is 1, Sub-unit is 0, Port is 4
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Playout-delay Mode is set to default
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 3 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 3 s
Companding Type is u-law
Region Tone is set for HU
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is disabled
Number Of Rings is set to 1
Supervisory Disconnect is dualtone mid-call
Answer Supervision is active
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 500 ms
And some from start-up config:
voice service voip
voice class custom-cptone radu
dualtone busy
frequency 450
cadence continuous
dualtone ringback
frequency 450
cadence 1000
dualtone out-of-service
frequency 450
cadence continuous
dualtone disconnect
frequency 450
cadence 167
voice class custom-cptone class1
dualtone busy
frequency 425
cadence 200 300
fax interface-type fax-mail
mta receive maximum-recipients 0
gw-accounting h323 vsa
gw-accounting voip
translation-rule 20950
Rule 0 ^00 011
interface Ethernet0/0
ip address 193.230.219.124 255.255.255.248
half-duplex
h323-gateway voip interface
h323-gateway voip h323-id BCI-Romania-GW
ip default-gateway 193.230.219.121
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
no ip http server
ip pim bidir-enable
AND:
voice-port 1/0/4
cptone HU
timeouts call-disconnect 3
timeouts wait-release 3
timing guard-out 500
caller-id enable
supervisory disconnect dualtone mid-call
supervisory answer dualtone
supervisory custom-cptone radu
no battery-reversal
I really hope you'll give me an answer.
Thank's a lot!
Re: Disconnect problem with CISCO 2610 Router
This is a common problem with FXO ports, I still have outstanding case open with Cisco, have you looked at the trouble shooting tips for FXO ..it gives you many different things to try on the voice port
also have you got the correct FXO card for your country?
good luck
Richard.
I've read a lot of documents regarding FXO, FXS, voice ports, dial-peer, etc, but I still have the problem...
Are there FXO cards specific to a country?
Tanks for your previous answer.
Radu
275
