02-23-2004 04:24 PM - edited 03-13-2019 03:58 AM
I have a PSTN line that is connected to an FXO port that i need to dial driectly to a particular handset. I have configured a PLAR connection type for this and the phone call works. the problem is that if the caller hangs up the phone, the called phone continues to ring untill the timeout of 180 seconds is exceeded.
Is there a way of having the voice port detect when the caller hangs up and to then terminate the call to the IP Phone?
Solved! Go to Solution.
02-26-2004 01:59 AM
Use plar opx XXX command in place of the plar command.
The opx option makes the voice port sense the incoming ringing, it then sets up the VOIP call , but it does not make the voice port go off hook. It keeps monitoring the POTS ring signal so if this goes away it clears down the VOIP call leg. If the VOIP call answers , it takes the FXO port off hook and bridges the POTS and VOIP call legs together.
You also don't need the bearer cap speech command as this only has relevance for ISDN type calls.
02-23-2004 05:26 PM
Looks like supervisory disconnect issue. Hope this link helps
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087b4f.html
02-23-2004 05:47 PM
i have managed to get the call to timeout earlier, but i still cant get the call to terminate when the calling party terminates the call from their end.
If i have a cptone defined, do i still need to create a supervisory custom cptone?
below is the voice port configuration
voice-port 2/0
supervisory disconnect dualtone mid-call
no battery-reversal
echo-cancel coverage 32
cptone AU
timeouts call-disconnect 30
timeouts wait-release 5
connection plar 348
bearer-cap Speech
Cheers
Darren
02-26-2004 01:59 AM
02-26-2004 01:48 PM
thank you.... that worked like a charm.
