Disconnecting a specific active call on voice gateway with PRI.
Hi All,
I'm looking for an option to disconnect a specific call that is active on a PRI voice port.
Somehow I have some active calls with duration of few days/week, and I’m looking to resolve it but I’m looking for a command to disconnect the call without disconnecting all other calls.
Thank you all, Kito.
Re: Disconnecting a specific active call on voice gateway with P
You can try the following:
issue a "sh call active voice brief" find the Tele call leg you want to disconnect.
Find out which ds0 within the ISDN PRI T1 the call is using.
Then, issue "clear interface serialX/Y:z" where x/y is the slot and controller number and z is the ds0 number.
This will clear the ds0 within the ISDN PRI and should drop the call.
Chinh
Hi Chinh,thanks for your answer, but somehow i dont have the command clear int serial, i have 2600 gateway with nm-hdv-1e1 , ios : c2600-is-mz.122-11.T1.bin and these are my option :
Gateway#clea interface ?
Async Async interface
BVI Bridge-Group Virtual Interface
CTunnel CTunnel interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-FrameRelay Virtual Frame Relay interface
Virtual-TokenRing Virtual TokenRing
So, please tell me if you can do it and i'm facing an ios issue or no.
Many thanks, again
Kito.
Hi Kito,
Are you sure you are using the NM-HDV for PRI signaling?
In our lab 2600 router, I have the following:
2611-4#s isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial1/1:15 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
TEI = 0, Ces = 9, SAPI = 16, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x0
Total Allocated ISDN CCBs = 0
2611-4#s isdn ser
PRI Channel Statistics:
ISDN Se1/1:15, Channel [1-31]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 3 3 3 3 3 3 3
Service State (0=Inservice 1=Maint 2=Outofservice)
State : 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
2611-4#clear int
2611-4#clear interface ?
Ethernet IEEE 802.3
Null Null interface
Serial Serial
2611-4#clear int serial 1/1:?
<0-23> Serial interface number
2611-4#clear int serial 1/1:1 ?
2611-4#
Chinh
Hi Kito
You need to first know what b-channel the call is on (show isdn serv will show you the states of each b-channel) then in serial-interface config (interface for d-channel i.e. 1/0:23) use isdn service command to take that b-channel out of service then back in service.
Thanks you all for your replies , it realy helped me, but one more thing,
how can I know which b-channel is the specific call running now?
when issueing the command "sh call active voice brief" i got the tele number which is the D-channel, also when issuing the command "sh isdn serv" I can not relate a specific call to specific b-channel ...
Again thank you all.
Kito
1814
