10-24-2002 12:46 PM - edited 03-12-2019 09:18 PM
I would like to disconnect my Unity 3.1(5) server from my 5.5-Sp4 server and reconnect to my newly added Exchange 2000-sp3 server.
I plan to follow the instructions:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/inst/inst31/inst_025.htm#94080
This essentially un-installs the Unity Configuration program.
My question is ... how does it come back? Does this happen as a result of restarting the Unity Services? or .... am I to re-install the Unity Configuration program?
10-24-2002 01:24 PM
You will need to re-run configuration setup and point at the Exchange 2000 server. Configuration setup will run a program called the syncher which will sync up SQL and AD.
Keith
10-24-2002 01:34 PM
Where is it ??? On the CD or in the commserver directory???
10-24-2002 02:07 PM
Configuration setup can be found in your install directory under \commserver\ConfigurationSetup\Setup.exe
10-24-2002 02:52 PM
Thanks ... I know this is a bit pendantic ... that's what I'm after.
The documentation needs to insert a section specific to what needs to be done when E2k is added to a production Unified Cisco Unity environment. Yes the jist of the information is there but not in a "step-by-step" fashion.
10-24-2002 03:12 PM
I filed defect CSCdz12045 on the documentation.
Keith
