Disk Mirroring on MCS-7925H-3.0
I've read this document: http://www.cisco.com/en/US/customer/products/hw/voiceapp/ps378/products_tech_note09186a00800942b4.shtml
regarding disk mirroring, but it mentions it is for 7930 or 7935 servers.
I have a 7925H-3000 that I would like to add a second hard drive for failure protection. Is this supported?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Disk Mirroring on MCS-7925H-3.0
Hi Ben,
It's hard to find much about the 7925H-3000 due to the EoL/EoS status of this product. You will see in this notice that RAID config is sadly not supported :(
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_end-of-life_notice0900aecd802a5ede.html
Hope this helps!
Rob
Hi Ben,
Hope this helps!
Rob
Okay, I was mistaken before about what server I have. I'm finding conflicting docs with what I show I have and what I can find.
On my CM server the tag reads: MCS-7825H-3.0-SERVER.
My SmartNET lists it as: MCS-7825H-3.0-IPC2.
In any of the compatibility matricies (I'm looking at going to 6.1), I can only find MCS-...-IPC1 servers listed.
When I mentioned adding a second HDD to the CM server to a TAC tech he didn't balk.
What's right and where can I find definitave info?
Hi Ben,
Hope all is well with you! Here is how to determine the actual model;
From Chris;
Look in registry under:
SOFTWARE\Cisco Systems\System Info\Hardware key
The older 7835H-3000 specs were very similar to the 7835H-3000 except for the redundant drives. I'm 99% sure if you have the older 7825 model you won't be able to set the Mirrored Drives up.
The Cisco MCS 7825H-3000 provides an entry level rack mount server that occupies only one rack mounting space. This server is equipped with an Intel Pentiumâ„¢ 4 3000 MHz processor, 40GB ATA hard drive and a single non-hot swap power supply.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/ps5166/index.html
Here is the 7835H-3000 which was different due to the RAID Drives;
The Cisco MCS 7835H-3000 provides a highly available mid-level rack mounted server solution that is equipped with an Intel Prestonia Xeonâ„¢ 3000 MHz processor, up to six hot-swap Small Computer Systems Interface (SCSI) hard disks, a Redundant Array of Independent Disks (RAID) 1/0 Controller, hot swap fans and redundant hot swap power supplies.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/ps5165/index.html
This doc shows all the supported models for the different CCM Versions including CCM 6.1 once you determine your exact model #;
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Thanks again for the help. I read it before, and rediscovered it after posting, the EoL doc you provided before listed the -IPC2 part number as part of the -3000 model.
At least I know for sure the EoL status and compatibility with CUCM 6.1
146
