Distinctive ring Callmanager 3.0(10)
It is possible to use different ring types for external (PSTN) and internal calls with a Cisco 3662 H323 Gateway (PSTN Connectivity via E1).
1 REPLY
Re: Distinctive ring Callmanager 3.0(10)
No. But a request was made a while back to enhance this so it could be configurable to treat an H.323 gateway as either inside (default) or outside, which would provide 2 short rings instead of 1 long ring.
Definitely in CallManager 3.1(2) there will be a service parameter called "H323NetworkLocationOffNet" which defaults to False. If set to True then it will do 2 short rings as I described. What I am not sure about is if the fix will also be in 3.0(12). The DDTS number is CSCdu52215.
108
