Community Member
Distinctive Ring type settings - 7960 (default and per line)
When setting the ring type on the 7960, there are many ring types available for the "default ring type". (eg: Chirp1, Chirp2, Analog synth, Are you there, etc etc). However when choosing the ring type for each line on the phone there is only list of "Ring 1, Ring 2, Ring 3 up to Ring 7".
Is there a way to get the full list of ring types for each line, not just the default ring type?
1 REPLY
Community Member
Re: Distinctive Ring type settings - 7960 (default and per line)
Because of the amount of memory available, only one line can take advantage of all available ring tones. Other lines can only use 'small' (simpler) ring tones (I think they should be less than 8k in size...)
212
