Community Member
Document for Cisco Switch Vs Avaya IP Phone non-compitability issues
I am planning to install a Avaya IP Phone on a Cisco POE Switch 3560. I know it will work with proper configuration. I like to know the non-compatibility issues or drawbacks using both. Please provide me a document says this so that I can finalize this.
Vidhu
Orbit
1 REPLY
Re: Document for Cisco Switch Vs Avaya IP Phone non-compitabilit
Hi!
Check if the Avaya phones support LLDP.A Cisco switch will generate both: CDP and LLDP-MED messages. When you connect a third-party phone to a Cisco switch the phone will discard CDP and get LLDP.
Please refer to:
http://www.cisco.com/en/US/technologies/tk652/tk701/technologies_white_paper0900aecd804cd46d.html
HTH!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
669
