Does Anyone have an Example H323 Gateway Config for E-1 PRI US to Israel?
We are going to ship a 2650 router with Srst to Israel and try to set it up as an H323 Gateway using E1 PRI off the Call Manager in NJ. If anyone has any config close to this it would be appreciated.
Re: Does Anyone have an Example H323 Gateway Config for E-1 PRI
what do you want to configure? here are some commands for h323 gateway working in Israel:
isdn switch-type primary-qsig/primery-net5
controller E1 1/0
pri-group timeslots 1-31
interface Serial1/0:15
description "D Channel 0"
no ip address
isdn incoming-voice modem
call-manager-fallback
ip source-address 10.2.1.1 port 2000
max-ephones 30
max-dn 40
dialplan-pattern 1 882.... extension-length 4
access-code fxo 9
voicemail 8501
Hope it will help you,if you'll need more help just let me know.
I am looking especially for Line Coding and Framing. Thanks for the Help :)
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20000504, FPGA: 8
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Thanks for all your help :)
160
