Does ATA186 work with IOS Telephony Service ?
I've upgraded ATA186 with software 2.12ms supporting SCCP. I'm trying to test it working with ITS running on a 3640.
The question is :
1) What have I do ?
2) How to provision .cnf files needed?
Best regards,
Christian Bongiovanni
Re: Does ATA186 work with IOS Telephony Service ?
I do not believe this is supported yet. You can use ATA 186 with Keyswitch but not with SRST as of yet. I have not heard any timeframe on this.
Thank you,
-Mckee
Ok, I dealt about ITS (IOS Telephony Service), that is Keyswitch phase II.
Are you trying to use the ATA 186 with keyswitch or SRST?
Thank you,
-Mckee
Hi, Mckee.
I'm trying to use ATA186 (SCCP software) with keyswitch (ITS v2.0). I got working only one port of ATA with keyswitch. Is it possible to get working port2?
Thanks.
95
