Does E1/ISDN-PRI Network Module support QSIQ ?
I need to know if E1/ISDN-PRI Network Module ( NM-1CE1B) on cisco2600 support QSIG Protocol (Basi-Call ECMA 142/143) and if yes what IOS version is required ?
1 REPLY
Anonymous
N/A
Re: Does E1/ISDN-PRI Network Module support QSIQ ?
No, you may need to use a Digital T1/E1 Packet Voice trunk Network Module.
Digital T1 and E1 interfaces are available on the Cisco 2600 Series. QSIG signalling is also available currently. You will need to load a PLUS image of Cisco IOS 12007XK to use the digital voice modules with QSIG.
Any Cisco IOS Plus Feature Set at revision 12.0(5)XK or later than 12.0(6)T for T1 and 12007XK or 12101T for E1 and QSIG.
120
