Community Member
Does Extension mobility CRA 2.2 supports with CM 3.2.2c ...?
Hi ,
I have installed CRA 2.2 and CCM ver 3.2.2c on a single machine. Trying to configure the Extension mobility.
if I login through the WEB using the following link the phone logs in to the profile as well as i can logout also.
http://10.10.10.243/loginservice/tools/sampleloginapp.asp
But if i try to login through the phone services , it displays the login and logout service , if select " login" it displays UPDATE and does not prompt for the USERID and PWD.
I refred the foll doc for the config
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00801545a2.shtml
anyone faced this problem....?
Thx in advance...
Regds
Anthony
1 REPLY
Bronze
Re: Does Extension mobility CRA 2.2 supports with CM 3.2.2c ...?
Reset the password for CCMSysUser in AD using
C:\dcdsrvr\bin\CCMPWDChange
Restart the following services
- Cisco Extended Functions
- Cisco Extension Mobility Logout
- Cisco Tomcat
95
