Community Member
**#** Doesn't reset our phones anymore
We have 7960 phones and Call Manager 4.1.2 ES63. We used to be able to reset our phones on the keypad by pressing the **#** keys. This does not work any more.
Anyone have ideas?
Hall of Fame Super Red
Re: **#** Doesn't reset our phones anymore
Hi Melanie,
Here is the key sequence you are looking for from the Cisco documentation for 7.2.x.
Resetting a Cisco IP Phone Model 7960 or 7940.
In previous releases, you could enter the reset code when a phone was on-hook at the main phone screen. With this release, you can no longer reset the phone from the main screen; instead, you must use the Settings screen or any other screen that does not accept user input. This new behavior results from a customer requirement to allow beginning a dialing sequence with * or # while the phone is on-hook.
To reset a Cisco IP Phone model 7960 or 7940, follow these steps:
Procedure
Step 1 From the main screen, press Settings to display the Settings screen.
Step 2 Enter **#** by using the keypad.
The IP phone goes through the reset cycle.
Note This reset sequence also works from any other screen that does not accept user input.
Here is a link to the actual document:
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_release_note09186a0080461f84.html#wp1109853
Hope this helps!
Rob
Please remember to rate helpful posts....
Community Member
Works like a charm! Thanks so much Rob!
Hi Melanie,
You are most welcome! Glad to help
Take care,
Rob
117
