double byte, unicode on CCM & IPPhones
What is the status of double byte & unicode characters display on 7940g/60g.
Does it require CCM 5.0?
Will the cisco solution cover everything, so can be able to display korean/chinese transparently, or a 3rd party module will be needed.
and in this case how it could fit in the picture.
1 REPLY
Bronze
Re: double byte, unicode on CCM & IPPhones
IP Phone 7940g/60g have a higher-resolution display, capable of rendering double-byte/Unicode characters and ideal for advanced graphical XML applications.
CCM 5.0 supports unicode, which means that items like Caller Name ID can
be expressed in double-byte characters
116
