DSP resource in 7200VXR
I had a PA-VXA-1TE1-24+ installed on 7200VXR. I want to use the 7 DSPs on the card to do transcoding in CCM. How can I add these in the CCM 3.3? In CCM, when you add a transcoder, you need to MAC for the port. Why is that? I am not clear about the transcoder/DSP concept and the way to configure it. I appreciate any help or refence doc.
1 ACCEPTED SOLUTION
Re: DSP resource in 7200VXR
The DSPs in a 7200 are not supported to be used as a Transcoder with CCM. This doc explains the supported hardware for CCM 4.1(3).
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edac1.html
Here is a doc that explains how to configure IOS based transcoders with CCM.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
Kevin
Kevin
Thanks for your great help.
136
