Dsp timeout errors on vg200
Can anyone give me a rundown on this error.
why it occurs etc ?
I have seen it on different plattforms.
errors is under the show voice dsp.
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 000 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 02 0 57564/9038
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 18 0 2759/166
C549 000 00 g711ulaw 3.6.15 busy idle 0 0 1/0:15 01 0 82449/17555
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 17 0 2604/161
C549 001 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 03 0 33840/3603
8
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 19 0 14360/1426
C549 001 00 g711ulaw 3.6.15 busy idle 0 0 1/0:15 02 0 39208/3093
7
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 18 0 1014/38
C549 002 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 04 0 11809/1116
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 20 0 2036/113
8
C549 002 00 g711ulaw 3.6.15 busy idle 0 0 1/0:15 03 0 74820/1087
8
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 19 0 4431/316
6
C549 003 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 05 0 2751/325
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 21 0 1505/103
C549 003 00 14400 3.6.15 busy idle 0 0 1/0:15 04 0 16744/431
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 20 0 5198/511
9
C549 004 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 06 0 1133/47
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 22 0 5249/402
C549 004 00 g711ulaw 3.6.15 busy idle 0 0 1/0:15 05 0 10745/883
7
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 21 0 1891/155
C549 005 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 07 0 3658/308
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 23 0 0/
C549 005 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 06 0 7685/749
7
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 22 0 8434/706
7
C549 006 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 08 0 1167/53
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 24 0 0/
C549 006 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 07 0 4578/426
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 23 0 1149/104
C549 007 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 09 0 2230/208
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 25 0 0/
C549 007 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 08 0 6015/592
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 24 0 5312/522
7
C549 008 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 10 0 162/18
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 26 0 0/
C549 008 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 09 0 3617/350
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 25 0 3826/333
7
C549 009 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 11 0 3081/300
9
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 27 0 0/
C549 009 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 10 0 2138/129
6
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 26 0 1492/85
C549 010 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 12 0 2754/144
7
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 28 0 0/
C549 010 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 11 0 1255/54
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 27 0 6357/604
7
C549 011 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 13 0 1263/59
9
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 29 0 0/
C549 011 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 12 0 1104/42
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 28 0 0/
C549 012 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 14 0 14130/1418
9
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 30 0 0/
C549 012 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 13 0 1704/107
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 29 0 0/
C549 013 02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 15 0 2027/142
03 {medium} 3.6.15 IDLE idle 0 0 1/1:15 31 0 0/
C549 013 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 14 0 9100/912
01 {medium} 3.6.15 IDLE idle 0 0 1/0:15 30 0 0/
C549 014 01 g711ulaw 3.6.15 busy idle 0 0 1/1:15 01 0 49070/7513
02 {medium} 3.6.15 IDLE idle 0 0 1/1:15 17 0 4102/329
7
C549 014 00 {medium} 3.6.15 IDLE idle 0 0 1/0:15 15 0 930/27
8
01:16:52: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x48: DSP ID=0x2: DSP Disc (
call mode=0)
01:16:56: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x48: DSP ID=0x2: DSP error
stats (call mode=-2124286568), chnl info(1, 14, 1)
01:36:39: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x48: DSP ID=0x2: DSP Disc (
call mode=0)
01:36:42: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x48: DSP ID=0x3: DSP Disc (
call mode=0)
01:36:50: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP Disc (
call mode=0)
01:36:54: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP error
01:38:00: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP Disc (
call mode=0)
01:38:04: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP error
01:38:32: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x1: DSP Disc (
call mode=0)
01:38:36: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x1: DSP error
stats (call mode=-2124286568), chnl info(1, 0, 0)
01:38:42: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x3: DSP Disc (
call mode=0)
01:38:46: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x3: DSP error
stats (call mode=-2124286568), chnl info(1, 1, 2)
01:42:26: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP Disc (
call mode=0)
01:42:30: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x3: DSP Disc (
call mode=0)
01:42:30: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x2: DSP error
01:42:32: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x1: DSP Disc (
call mode=0)
01:42:34: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x3: DSP error
stats (call mode=-2124286568), chnl info(1, 2, 2)
01:42:36: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x43: DSP ID=0x1: DSP error
stats (call mode=-2124286568), chnl info(1, 1, 0)
01:45:02: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 0x48: DSP ID=0x2: DSP Disc (
call mode=0)
Re: Dsp timeout errors on vg200
Basically these are software problems caused by DSPware crashing for various reasons. Please refer to this link for more information.
http://www.cisco.com/warp/public/788/products/dsp-trbl.html
-ben
Thanks ben
The latest firmware is being run on this box.
The doco below says the bug is fixed with this release.
This is a VG200 in this instance.
Should i address this issue any otherway or just leave it.
An what is the meaning of---> chnl info (1, 1, 2) in the error below
Its not the dsp id
The DSPs on the PVDM-12 on SIMM socket 4 have an id=0,1,2
there are a few 1 1 0 or 1 14 1
thanks
A Cisco router that is running Cisco IOS Release 12.2(1) or 12.2(0.5g) may
experience digital signal processor (DSP) reloads or fail to respond after the
following error messages are displayed:
%VTSP-3-DSP_TIMEOUT: DSP timeout on event 6: DSP ID=0x1: DSP error stats, chnl
info(5, 13, 0) %VTSP-3-MSGSNDFAIL: channel:5/0:15 (54516) DSP ID:0x1 Message
There is no workaround.
Update:
This DSP firmware defect is fixed in DSP Release 3.6.15 / VCWare Release 9.19
and DSP Release 3.4.49 / VCWare Release 7.38, as well as newer versions of
these firmware releases.
221
