Dspfarm issues
Ayad
I have a problem to register an IOS conference bridge to my callmanager.
I have juste this value "0" withthe dsp confbridge maximun session command ?
Please if someone can help me !
5 Replies 5
Looks like you don't have enough DSPs.
How many DSPs? And how are they allocated?
I have the same problem.
What I have is a Cisco2811 with PVDM2-16.
What do I need? Do I need 2 PVDM2-64? or just 1 PVDM2-64?
It says on the link you provided as
Prerequisites DSP Resources:
PVDM2 on Cisco 2800 series or Cisco 3800 series
Would NM-HDV or NM-HDV2 work? it also needs PVDM2 modules installed on it?
Thanks.
gogasca
Level 10
Level 10
In the 28XX platform you use profiles not the command you are using that is for PVDM-X.
DSP calculator is your friend.
Check the link Jorge sent you is a good one.
jaregalado
I just came across this same problem with IOS 12.3(11)T8 on a 2811 router, just upgraded to 12.3.(11)T9
and the problem went away.
Regards.
