Community Member
Dspfarm issues
I have a problem to register an IOS conference bridge to my callmanager.
I have juste this value "0" withthe dsp confbridge maximun session command ?
Please if someone can help me !
Re: Dspfarm issues
Community Member
Re: Dspfarm issues
Looks like you don't have enough DSPs.
How many DSPs? And how are they allocated?
Community Member
Re: Dspfarm issues
I have the same problem.
What I have is a Cisco2811 with PVDM2-16.
What do I need? Do I need 2 PVDM2-64? or just 1 PVDM2-64?
It says on the link you provided as
Prerequisites DSP Resources:
PVDM2 on Cisco 2800 series or Cisco 3800 series
Would NM-HDV or NM-HDV2 work? it also needs PVDM2 modules installed on it?
Thanks.
Green
Re: Dspfarm issues
In the 28XX platform you use profiles not the command you are using that is for PVDM-X.
DSP calculator is your friend.
Check the link Jorge sent you is a good one.
Community Member
Re: Dspfarm issues
I just came across this same problem with IOS 12.3(11)T8 on a 2811 router, just upgraded to 12.3.(11)T9
and the problem went away.
Regards.
187
